В поисках нужной информации наткнулся на этот блог...
А тема-то актуальная
Предлагаю "длиться" переменными окружения (environment variables) влияющими на работу CATIA
'Startup
CATNoStartDocument=no; CATNoStartDocument=1 'It doesn't make CATProduct on starting up (Disable product at startup) {instead of CATNoStartDocument I use in the cnext command line the option " -object none"}
CNEXTBACKGROUND=no 'It doesn't display background
CNEXTSPLASHSCREEN=no 'It doesn't display splashscreen (cnext command line the option "-nowindow")
CNEXTOUTPUT=CONSOLE 'It runs console window (Display Catia's logs in command windows) Включает консоль. Если вместо CONSOLE указать имя файла, то будет сформирован файл трэйса (trace) с указанным именем
'Path
AVAILABLE_CACHE_DIR_PATH=(Global CachePath)
CATReffilesPath=Officialpath;Projectpath 'R11 or higher
CATReferenceSettingPath= 'Path to the default settings of the environment
CATFeatureCatalogPath=$CATFeatureCatalogPath '.../resources/graphic
CATDisciplinePath=/tools/catia/startup/bmw/ProjectData
CATCache=/catcache/v5cache/$user
CATPRINTLOG=/var/catroll/$USER/Print.log
CATAlbumRepository=C:\CAD\CATIA\Album 'Album adjust path
PATH= 'Search on UNIX. Directories with application programs and system commands
LIBPATH= 'Search for the libraries on AIX
LD_LIBRARY_PATH= 'Search for the libraries on SOLARIS
LD_LIBRARYN32_PATH= 'Search for the libraries on IRIX
SHLIB_PATH= 'Search for the libraries on HPUX
CATW3PublishPath=DSKEY_TMPDIR 'Enovia Portal
CATSharedWorkbookPath=DSKEY_TMPDIR 'Path for Workbooks of Enovia portal
'Screen
'These 4 variables are used to adjust the display for V5 on Windows (circle may
'appear as oval). Pls find below a sample of settings for nw8240 mobile workstation.
'Resolution set to 1920x1200 wich makes a ratio of 1920/1200=1.6.
'Then you need to apply the same ratio for the screen size related variables.
'Display height of nw8240 is about 207mm, then :
CATWidthPixelOfScreen = 1920 'in pixel
CATHeightPixelOfScreen = 1200 'in pixel
CATWidthMMOfScreen = 207x1.6 = 331.2 'in mm
CATHeightMMOfScreen = 207 'in mm
CATLM_ODTS=1 'Disable license error messages at startup
SHOW_CST_CHILDREN=1 'Display stresses in the parents specification tree in sketcher
MM_NO_REPLACE=1 'Associativty about replacement of components cloned with different
MFG_MULTI_MP_APPLY=1 'multi instantation the manufacturing process
MFG_CATMFG_REMOVE_MOTION_TOOL_CHANGE=1 'remove th GOTO X Y Z during toolchange in APT file
TAILLE_MEMOIRE_CHOISIE=1 'Optimize IGES export memory
SHOW_CST_CHILDREN = 1 'R13 : Sketcher: Constraint-Tree Visualization + dependencies of the constraints are displayed (Parent-Children)
SAVE_AS_ONE_PDF=1 '
CATGraphSize = 5 'в мм. Настройка по умолчанию размера шрифта в дереве
CGM_IMPORT_SCALEMODE = 1 'импорт CGM d масштабе 1:1
'Add New Elements and Fitures
CATDlgAdvancedToolbarPositioning=1 'The Toolbar behavior improves
IRD_PRODUCTTOPART=1 'R11 only : It will enable a hidden fuction: CATProduct to CATPart...and, in "Assembly WorkBench" look under Tools menu
IRD_PART_COMPARISON=1 'up to R12 : Сравнение деталей с одним и тем же UUID. bietet die Partdesign-Umgebung unter Tools die Funktion "Teilevergleich"
L_WILSON_LAN=1 'Access to Wilson's spline curves
CGM_ROLLINGOFFSET=1 'R10 SP4 : Access to the Rolling Offset option in GSD
SHM_ONLY_CANONICAL_FLANGE = 1 'Предотвращает производства криволинейных изгиба зон в GSMD и ASL flange.
Elec_Ctx_Design=1 'Creates a new option "Contextual Links" in Tools / Options / Eq & Syst / EUI
Elec_RouteSurface=1 '"BNS Routing on Surface" Funktionality. Fast and easy routing of BNS on surfaces incl. CGR
SMD_NEW_WORKBENCH_ACCESS = 1 'R11 - R15 : 1 = старые и новые функции отображается; 0 = только старые функции отображаются
SMD_OLD_WORKBENCH_HIDE = 1 '1 = cкрыть cтарые функции
'VPM variable
CV5_VPM_REPOSITORY=$CATTemp
CV5_VPM_ForceExtractSave=1 'ExtractSave M?lichkeit in VPM is only set this variable m?lich. Hotfix(PMR)9871
CV5_VPM_ENV=VPMENV
CV5_VPM_DMUUTIL=1
CV5_VPM_DRAW666=1
CV5_VPM_NewSave=1
CV5_VPM_TRANSACTION=1 'Highlight Update Button nach Modifikation
CV5_VPM_Commit=1 'Immediate commit einer Product Ver?derung in VPM
CV5_VPM_InstanceTS=1 'Assembly Drawing Management in VPM (reroute, impact graph)
CV5_VPM_InstanceName=1 'Instance Name Persistency in VPM
CV5_VPM_XCONT=1 'DB-Verbindungsproblem in Verbindung mit Nomad
CV5_VPM_NOPERFOTS=1 'PMR (to reload V4 model if timestamp is new)
CV5_VPM_PERFOCONT=1
CV5_VPM_READONLY=1
CV5_ASSDRWLINK=1 'Assembly Drawing Management in VPM (reroute, impact graph)
CV5_REC_FORBIDDEN_RULES="PubExp_NewObject,ProdStructExp_NewObject"
CV5_REC_QUERY_DEFAULT=7
CV5_REC_RELOAD_ForceInconsistentDocUuids=1
ChangeNameOnReplace = 1 'ENOVIA/VPM : Название экземпляра (instance) в течение замены или обновления. Синхронизация экземпляра со ссылкой
'V4/V5 migration variable
KEEP_HIDDEN_ELEMENT=1 'No Show Elements are also migrated
cleanV4Topology=1 'R11 : It cleans topology automatically
CATMigrSolidMUV4AsPart=1 'R10 : By Pasting "As_SPEC" It migrates SolidM into CATPart
REPORT_BREP_INFO=1 'It makes migration report
V5V4SaveAsVolume=1 'It migrates *SOL to *VOL
V5V4CleanTolerance=0.01 'mm - Maximum gap used by automatic topology cleaner
V5V4MaxSimplif=1 'It tries to concatenate small surfaces with large adjacent surfaces
V5V4Error=1 '
MDL_WSP_NB = 200 'Увеличение числа "рабочих" (по умолчанию 50)
V4ToV5DetailGeomRequired=1
V4V5ForceDetailToExplode=1
V5V4CreateCurves=1
SewingNoIntersect=1 'No Intersection mode to simulate the V4 behavior for better V4/V5 migration
ASSY_SMARTMOVE_VIEWER = 1
CATDUA_DOMAIN = 1 '
CATProductScenes = 1
CATSceneVPMNaming = 2
PS_DocChooser_NoDefault = 1
CATM2V5ErrorOnMergeKO = 1
DMU_CLASH_DEBUG_FILE=1 'Reporterstellung aus ITFCheck
DMU_CLASH_BATCH_MANAGE_SHAPE=1
DMU_CLASH_NBPROD_TOGETHER=301
DMU_CLASH_DEBUG_RESULT_FILE=/tmp/ClashDebug.trace
DMU_CLASH_DISPLAY_INTERSECTION_VOLUME_CXR8_SP2=BOOLEAN_32
DMUBuilderProduct=$HOME/empty.CATProduct
CAT_CLEAN_BROKEN_MATLINKS = True 'Ремонт Ссылки на материал
MAT_REFRESH_AFTER_POWERCOPY_WITH_KWE_PARAMETER = 1 'R18 : обновить материал при Powercopy
ASL_UPWARD_COMPATIBILITY_TO_R16SP4 = 1 'R16 or higher : Enables various patches fix> = 20 for problems with sheet metal parts zubeheben the R16 before it was created.
CAPTURE_WITHOUT_PBUFFER = 1 'R14: Проблемы с видеокартами с памятью pBuffer
OMB_RESOLUTION_LINK_CACHING = TRUE
ATTR_COLORS_ON_CPARWL = 1 'R16 or higher :
EmptyXmlNoError=1
DRW_STD_THICKNESS=1
DRW_FILLET_FILTER=1
DRW_NEW_HATCHING=1
DRW_UPDATE_STATUS=1
DRW_ViewPosMode=1
DRW_DC=1
MulProcModOff=1
PRD_Externalize=1 'Convert components into Products
CATCheckRessources=TRUE
CATApplicativeContainerFilter="ContDressUp"
PRINT_PDF_TEXT_DISCRETIZED=1 'Fixes Font problems with PDF creation
PRINT_CAPTURE_DPI=300.0
PRINT_SETTING_PATH=$HOME/CATTemp 'to make PRINT_CAPTURE_DPI working, its necessary to define this variable
PRINT_CAPTURE_RASTERFORMAT=TIFFG4
PRINT_WITHOUT_DEPTH=1 'V5R10 only : remove the mask from the text on the print (Печатать символы и текст без толщины)
CATPDM_NOMAD_PATH=$HOME/NOMAD
CATDraftingResetToStandard=1
R10SP3_ASSY_UPD_ICON=1
V5MEM=7
CATIAV5_FBDI=1
CATIAV5_PRODUCTPUB=1
Mask_PTS_Visible=1 'makes visible icons together: & electrical assembly (context ...) icons
EV5_NamingAppContainer=1
INTEROP_CONTAINER_V5R8=1
SPA_NEW_XML_EXPORT=1
CAT_SIZE_CONTROL=YES
BMW_ALLCATPART_BATCH=1
BMW_CAA_DEVENV=1
BMW_IRD_R10=1
BMW_PUBLISH=1
CATCocDirectMoveModes=1
CATCocPlaneSelectArea=1
ABF_V5R12_CUSTOMER=1
MIGRATION_INTERFACE=CATIE3DMigration
'System variables
CAT_VBO_ALLOWED = 1 'R18 or higher : Увеличивает производительность для больших моделей и моделей на базе современных материалов CgFX шейдеров благодаря поддержке со стороны OpenGL. только в Windows 32-битной И 64-битных (XP, Vista)
MAV писал(а):Обновил свою коллекцию переменных...
CATCompositesNewIML=2
CATCompositesNewTopSurfaces=1
CATCompositesPlyBook=1
CATCompositesR19LA=1
CATCompositesR19SP5=1
CATCompositesAddIn=1
CATCompositesR18SP6LA_IntPlyTableTest=1
car2ner писал(а):... CNEXTBACKGROUND=no у меня работает только в виде системной переменной ...
