car2ner писал(а): ....Затем через catenv зарегистрировал в системе. ...
Fluffy писал(а):А если проще, загружаешся в висту в БЕЗОПАСНОМ режиме и ставиш как обычно на ХР без проблем, Удачи.
To create or customize an environment using the setcatenv command
You can also customize environments using the setcatenv command. This command lets you create both user and global environments.
The command is located in:
C:\Program Files\Dassault Systemes\B18\intel_a\code\bin (Windows XP Pro)
C:\Program Files\Dassault Systemes\B18\win_b64\code\bin (64-bit code on Windows XP Professional x64 Edition)
C:\Program Files (x86)\Dassault Systemes\B18\intel_a\code\bin (32-bit code on Windows XP Professional x64 Edition)
The full list of options for the command:
setcatenv
is as follows:
Operating Environment Options
These options specify the general operating environment:
* -cs: specifies the name of the product line for which the environment is being created;
The value is CATIA (default) for the CATIA product line.
* -e: environment file name ; the "-e" option is mandatory
* -d: specifies an existing directory in which the environment file will be created (it does not create the directory if it does not exist);
if you do not specify "-d", the environment will be created in:
C:\Documents and Settings\user\Application Data\DassaultSystemes\CATEnv
where "user" is "All Users" for a global environment, or "myuserid" for a user environment
* -p: specifies the installation folder, and is mandatory (by default, it is set to the default installation folder: C:\Program Files\Dassault Systemes\B18)
* -server: creates an environment suited for server type environments. The CATUserSettingPath variable value differs between a server environment and an interactive environment. The "-e" option is mandatory when specifying server environments, and always overwrites an existing environment with the same name. Consequently, system administrator rights are required for using this option
* -cf: specifies the name or path of an existing environment from which you create a new environment.
For example, the command:
setcatenv -e MyNewEnv -cf CATIA.V5R18.B18
creates the new environment MyNewEnv from a copy of CATIA.V5R18.B18.
This allows you to inherit previous customizations without having to recreate them in the new environment.
For example, the CATReferenceSettingPath variable is frequently used to store settings locked by the administrator, and may concatenate several different levels of settings. Copying an existing environment saves you time because you do not having to customize the new environment.
Note that if you do not use the "-cf" option, all the variables are set with their default values in the new environment. If only the name is specified in the "-cf " option, the template environment is searched in the default storage directories (user or global).
Behavior Options
These options determine a type of behavior:
* -v yes/no:
o -v yes (default): verbose mode
o -v no: non-verbose mode.
* -new yes/no:
o yes ( default): an environment with the same name (if it exists) is overwritten
o no: if an environment has the same name, this time it is not overwritten (nothing happens).
However, note that if no environment using the same name is detected, a new environment is created in both cases (whether you use "yes" or "no").
* -tools: sets up the Tools menu containing the Environment Editor V5R18, Nodelock Key Management V5R18, Settings Management V5R18, Software Management V5R18, Batch Management V5R18 and Printers V5R18 commands.
This is an exclusive option: run this command once like this:
setcatenv -tools -cs MyProductLine
* -desktop yes/no: sets up the desktop representation of the environment, if it does not already exist. The default is "yes". Equivalent to "-icon yes" "-menu yes".
* -icon yes/no: creates a startup icon on the desktop; default is "yes"
* -menu yes/no: creates a startup icon in the Start menu; default is "yes"
Action Options
These options specify a particular creation or modification action:
* -a user/global: specifies whether you are creating a user or global environment. The default value is "user". Note that you need administrator rights to create a global environment.
* -h: displays help.
The catenv.log log file logs environment creation and modification operations. The log file is created in the temporary folder in one of the following locations:
the path specified by the TMP environment variable
the path specified by the TEMP environment variable, if TMP is not defined
the current directory, if both TMP and TEMP are not defined.
Creating an environment using the setcatenv command sets up the following environment:
* sets up Start->Programs->MyProductLine menu by adding the shortcut for your environment
* and creates the shortcut for your environment on the desktop.
If you create a new environment, you can start a session using the new environment with the command:
cnext -env my_new_environment -direnv MyEnvDirectory
where "my_new_environment" is the name of the environment you created, and "MyEnvDirectory" is the name of the environment directory.
cnext /regserver -env MyEnvironment -direnv MyEnvDirectory
[PTM] писал(а):это самый топорный метод) но работает
keeper писал(а):odyvantshik, viewtopic.php?f=157&t=386&p=2513&hilit=CXINST.exe#p2513
А в будующем пользуйтесь поиском
