[PTM] » 30 июл 2012 08:33
В свое время тоже была такая пролема.Не помню что помогло, помню только что долго ковырял setcatenv.exe.
В help'е информации хватает...
Еще есть
HKEY_LOCAL_MACHINE\SOFTWARE\DassaultSystemes (Windows XP Pro and Windows XP Professional x64 Edition)
The key "EnvNameSuffix" is added containing the key "0" which specifies the destination folder. Additional entries are made each time you install the same release in a different location, and the key number will be incremented for each installation as follows: "0", "1", "2", etc.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Dassault Systemes EnvNameSuffix_0 (Windows XP Pro and Windows XP Professional x64 Edition)
Specifies the application name for uninstallation purposes; additional entries are made each time you install the same release in a different location, and the key number will be incremented for each installation as follows: "EnvNameSuffix_0", "EnvNameSuffix_1", etc.)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths (Windows XP Pro and Windows XP Professional x64 Edition with 64-bit code)
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\App Paths (Windows XP Professional x64 Edition with 32-bit code)
Sets up the Start > Run... command so you can enter the appropriate command to start a session for your product line). This key is now integrated when using the /regserver and /unregserver command options.
взято из Instalation&Deployment Guide
About the Environment Created on Your Computer on Windows
