- Код: Выделить всё
Dim rels As Relations
Set rels = prod.Relations
For i = 1 To rels.Count
Dim val As String
Dim comment As String
Dim name As String
Dim outParameter As Parameter
val = Replace(rels.Item(i).Value, "deleted_", "")
comment = rels.Item(i).comment
name = rels.Item(i).name
Set outParameter = rels.Item(i).GetOutParameter(1)
rels.Remove (rels.Item(i).name)
Dim rel As Relation
Set rel = rels.CreateFormula(name, comment, outParameter, val)
Next i
На строке
- Код: Выделить всё
ругается : class does not support automation or does not support expected interface
