Product Coordinates
СообщениеДобавлено: 13 июн 2012 14:08
saravanakumarr
Hello,
Programmatically how to extract the coordinates(X,Y,Z &
Angles) of all the children of a product.
I am using the below code. But an error comes as below
shown image.
For i = 1 To Products.Count
    Dim Product As Product
    Set Product = Products.Item(i)
    Dim ProductPos As Position
    Set ProductPos = Product.Position
    Dim iAxisComponentsArray(11)
    ProductPos.GetComponents iAxisComponentsArray
Next i
Error Msg:
Compile error: Function or interface marked as restricted, or the function uses an Automation type not supported in Visual Basic.
:dash1:
Re: Product Coordinates
СообщениеДобавлено: 14 июн 2012 08:47
Dim d As Product
Set d = CATIA.ActiveDocument.Selection.Item(1).Value
For i = 1 To d.Products.Count
    Set Product = d.Products.Item(i)
    Dim ProductPos 'As Position
    MsgBox CStr(iAxisComponentsArray(0)) + CStr(iAxisComponentsArray(1))
Next i
Try this. On the future - selection also not like "as selection"
СообщениеДобавлено: 14 июн 2012 10:29
saravanakumarr
Thank you so much. That solved the problem.
СообщениеДобавлено: 14 июн 2012 10:56
Индусы и сюда добрались...
Use search before asking. This will show your respect to the community. I believe you haven't even googled for your issue as there are hundreds pages that have a solution.
СообщениеДобавлено: 14 июн 2012 10:58
И среди них бывают нормальные программисты.
СообщениеДобавлено: 14 июн 2012 12:04
AKB
Wireless_Fidelity писал(а):Индусы и сюда добрались...
Seoul, Korea :-)
