Wireless_Fidelity писал(а):Самое простое - использовать Selection (метод Search "'Assembly Design'.Product,all")
Более правильное - сделать рекурсивный обход через коллекции Products.
Для каких целей нужен список?
function LeftStr(Const Str: String; Size: Word): String;
begin
LeftStr := Copy(Str, 1, Size)
end;
function RightStr(Const Str: String; Size: Word): String;
begin
if Size > Length(Str) then Size := Length(Str);
RightStr := Copy(Str, Length(Str)-Size+1, Size)
end;
procedure ScanProductTree(ItemProd: Product; Level: Integer);
var
n, i: Integer;
iVar: OleVariant;
iDoc: Document;
fName: String;
fExt: String;
begin
iDoc := ItemProd.ReferenceProduct.Parent as Document;
fName := iDoc.Get_Name(); // имя файла с расширением
fExt := RightStr(fName, Length(ExtractFileExt(fName))-1);
fName := LeftStr(fName, Length(fName) - Length(ExtractFileExt(fName))); // имя файла без расширения
if UpperCase(fExt) = 'CATPART' then
begin
//MessageDlg('ItemProd - CATPART', mtInformation, [mbOK], 0);
// Действия если ItemProd - CATPART
end
else if UpperCase(fExt) = 'CATPRODUCT' then
begin
//MessageDlg('ItemProd - CATPRODUCT', mtInformation, [mbOK], 0);
// Действия если ItemProd - CATPRODUCT
end;
n := ItemProd.Products.Count;
if n > 0 then
begin
for i := 1 to n do
begin
iVar := OleVariant(i);
ScanProductTree(ItemProd.Products.Item(iVar), Level + 1);
end;
end;
end;
Option Explicit
Sub CATMain()
' get root product of active document
Dim prdRoot As Product
On Error Resume Next
Set prdRoot = CATIA.ActiveDocument.Product
If (Err.Number <> 0) Then
Err.Clear
MsgBox "Can't get root product. Check document type"
Exit Sub
End If
' launch Excel
Dim oExcel As Object
Set oExcel = CreateObject("Excel.Application")
Err.Clear
MsgBox "Can't start Excel. Check if it was properly registered as COM"
Exit Sub
End If
' create a workbook and get a sheet from it
Dim oExcelSheet As Object
Set oExcelSheet = EXCEL.Workbooks.Add().ActiveSheet
oExcel.Visible = True
' export product structure to Excel starting from first row and first column
ExportProductStructure prdRoot, oExcelSheet, 1, 1
Sub ExportProductStructure(prdRoot, oExcelSheet, iRow, iColumn)
' WRITE NAME OF ROOT PRODUCT IN EXCEL
'oExcelSheet.Cells(iRow, iColumn) = prdRoot.Name
oExcelSheet.Cells(iRow, iColumn) = prdRoot.PartNumber
' GET LIST OF CHILD PRODUCTS
' go through all products of previous level
Dim iNbChildren
iNbChildren = prdRoot.Products.Count
' make sure that we continue expanding product on the current row
If (iNbChildren > 0) Then
iRow = iRow - 1
End If
Dim prdChild As Product
Dim iChild
iColumn = iColumn + 1
For iChild = 1 To iNbChildren
' get another child product
Set prdChild = prdRoot.Products.Item(iChild)
' RECURSIVE CALL
iRow = iRow + 1
ExportProductStructure prdChild, oExcelSheet, iRow, iColumn
Next
' return back to previous level
iColumn = iColumn - 1
'iRow = iRow - 1
Wireless_Fidelity писал(а):У "одинаковых" деталей в свойстве ReferenceProduct будет стоять один и тот же продукт.
Привожу пример рекурсивного обхода с выгрузкой структуры дерева в Excel:
- Код: Выделить всё
Option Explicit
Sub CATMain()
Err.Clear
Exit Sub
End If
' launch Excel
Err.Clear
Exit Sub
End If
Dim iNbChildren
iRow = iRow - 1
End If
Dim iChild
' RECURSIVE CALL
iRow = iRow + 1
Next
'iRow = iRow - 1
Wireless_Fidelity писал(а):Из каких именно? Посмотрите документацию, родительский элемент любого объекта доступен через свойство Parent.
