Имеется CATVba, в нём закодирован интерфейс
Spoiler :
- Код: Выделить всё
Create the command line to launch the MyBrowse JAR file to select a JT file
Dim JRE_INSTALL
JRE_INSTALL = regValue & "\jre\bin\java.exe"
JRE_INSTALL = Chr(34) & JRE_INSTALL & Chr(34)
Dim Browse_JAR
Browse_JAR = regValue & "\lib\MyBrowse.jar"
Browse_JAR = Chr(34) & Browse_JAR & Chr(34)
Dim browse_cmd, browse_cmd1
browse_cmd = JRE_INSTALL & " -jar " & Browse_JAR
Dim dlgTitle
dlgTitle = "Select JT File to Insert"
dlgTitle = Chr(34) & dlgTitle & Chr(34)
'Invoke the MyBrowse jar file to launch the JT File Selection dialog
Dim tdiff
tdiff = Len(sCurDir) - InStr(sCurDir, ":")
'If the current directory is a root directory, then we pass it as an argument without quotes, else with quotes
If tdiff = 1 Then
browse_cmd1 = browse_cmd & " 0 0 false false " & dlgTitle & " " & sCurDir & " " & sCurDir
Else
browse_cmd1 = browse_cmd & " 0 0 false false " & dlgTitle & " " & sCurDir1 & " " & sCurDir1
End If
Dim x
x = sh2.Run(browse_cmd1, 0, True)
'Determine the JT Filename to be opened
Dim JT_filename, sFile, sFile1, oFile, sText
sFile = sCurDir & "\tempFile.txt"
sFile1 = Chr(34) & sFile & Chr(34)
If oFSO.FileExists(sFile) Then
Set oFile = oFSO.OpenTextFile(sFile, 1, False)
sText = oFile.ReadLine
If Trim(sText) <> "" Then
If InStr(sText, " ") = 0 Then
JT_filename = sText
Else
JT_filename = Chr(34) & sText & Chr(34)
End If
Else
MsgBox "The JT file selected could not be found.", vbCritical
Exit Sub
End If
oFile.Close
'Delete the tempFile.txt which was created by the JAR file
oFSO.DeleteFile sFile, True
Else
MsgBox "The JT file selected could not be located.", vbCritical
Exit Sub
End If
Задача: сделать так, чтобы можно было выбрать не один файл, а список файлов или папку, в которой находится много файлов
