Генерация доп деталей в каталоге спецификации
В хелпе написано
кто нибудь такое делал?...что-то у меня влоб не получилось...
The specifications catalog provides another important function - it can generate new parts for a project without increasing the number of parts in the main catalog. This is done because the specifications catalog can apply a value to an attribute on a part in the main catalog. This attribute is referred to as generic attribute. This can significantly reduce the number of parts you have in your main catalog. The way it works is like this: say you have four projects in your company that use pipe made of four different materials. You do not have to create four main catalogs, or add four pipes to one catalog, each with a different material defined. Instead what you can do is add one pipe to your main catalog with the attribute 'materialcode' (or any term you choose) but with no value defined for this attribute. Now, when you create the attribute filter file (explained in Step 9 below) you list the material you want for a particular project and put an asterisk after it. The material you have listed will be defined for the property materialcode. All you have to do is make four specifications with the four different materials you need.
In addition to specifying the properties of parts, you also have to associate rules tables. This application incorporates intelligent design functions. This means that as you design, the application ensures your designing meets certain criteria. These criteria are established by the design rules. For instance, the design rules will match the threaded end of a pipe to the threaded end of a part. (You can override the rules if you want.)
