Генерация доп деталей в каталоге спецификации
Сообщение [PTM] » 13 ноя 2007 16:01
В хелпе написано
The specifications catalog provides another important function - it can generate new parts for a project without increasing the number of parts in the main catalog. This is done because the specifications catalog can apply a value to an attribute on a part in the main catalog. This attribute is referred to as generic attribute. This can significantly reduce the number of parts you have in your main catalog. The way it works is like this: say you have four projects in your company that use pipe made of four different materials. You do not have to create four main catalogs, or add four pipes to one catalog, each with a different material defined. Instead what you can do is add one pipe to your main catalog with the attribute 'materialcode' (or any term you choose) but with no value defined for this attribute. Now, when you create the attribute filter file (explained in Step 9 below) you list the material you want for a particular project and put an asterisk after it. The material you have listed will be defined for the property materialcode. All you have to do is make four specifications with the four different materials you need.
In addition to specifying the properties of parts, you also have to associate rules tables. This application incorporates intelligent design functions. This means that as you design, the application ensures your designing meets certain criteria. These criteria are established by the design rules. For instance, the design rules will match the threaded end of a pipe to the threaded end of a part. (You can override the rules if you want.)
кто нибудь такое делал?...что-то у меня влоб не получилось...
Re: Генерация доп деталей в каталоге спецификации
Сообщение ExtraRight » 13 ноя 2007 16:52
Если мне память не изменяет - Specification catalog нужен для выборки из главного каталога тех элементов, которые можно использовать в данном конкретном проекте (Project.xml). На самом деле использование Specification cataloga - достаточно запутанное дело. Мы отключали кнопку Specification при вставке в Equipment&Systems модулях и старались не пользоваться этим инструментом. Единственное место, где вроде бы (во всяком случае раньше) нельзя было обойтись без Specification catalog - это при работе в связке 2D schema - 3D (то есть "Schematic driven"). В таком случае в Specification catalog мы выбирали фильтры элементов таким образом, чтобы все элементы из главного каталога попадали в Specification. Вообще это делается путём генерации по фильтру ,но там всплывали свои нбансы, правда я их могу и не вспомнить.
Сообщение [PTM] » 13 ноя 2007 20:52
вообще использование каталога спецификации достаточно просто...
впринципе несложно создавать фильтры как вручную( гглавное использовать словарик) так и автоматом ( эксель-текстовик)...
впервом случае долго если необходимо делать выбоорку более чем 2-3 ветки...но наглядней определять фильтры.
и если вы создали стандарт то каталог спецификации создать..... ну оч легко :twisted:
но именно интересует возможность генерации доп частей.без увеличения основного каталога
